69427
Just curious what people are using. When I first got my '69 the fresh air vent to the RH valve cover was plugged with one of those 710 plugs, and the filter base was also plugged. I never gave it any thought at the time, and eventually (a few years later) I welded in a tube with the flame arrestor into the filter base and then hooked up a hose to the valve cover to complete the PCV loop. I've been running a 780 VS Holley for several years, and was recently doing some work on my spare 850 DP when I noticed that the vent tube in the filter base hits the secondary accelerator pump linkage. Now it makes sense why the filter base was modified when I first got the car. The previous owner had replaced the Quadrajet with a double pumper spread bore Holley, and I'm assuming that he (or most probably, his mechanic)encountered the same interference with the secondary pump linkage.
So, my question is: What filter base are (BB) guys using when they run double pumper Holleys, and are they able to use the vent hose to the RH valve cover?
Thanks,
Mike
Thanks,
Mike
