JeffP1167
I found this picture on ebay but thought the harness would be a 1 piece thing with a bulkhead connector that passes through the firewall.
Aside from a change in IAC wiring and addition of TPI injector pigtails (I have a 90 camaro TPI harness to make the changes) How can I add a AIT sensor and assume I will have to run wiring for a VSS as well.
The VSS I assume I could just drill hole in trans tunnel and run wiring down to it. I plan on mounting my 90 vette ecm in the stock 82 location.
I assume CFI is a MAP type system so only a few changes will have to be made to my wiring along with splicing the ecm pigtails. I really don't want to go with ecm relocation if possible and would like to use as much of the 82 harness as possible since it is in excellent shape. I also want to add VATS to my car as well but think the 90 vette has no decoder box like the F-body has and it is internal to the CCM.
here is the cfi harness I found, what other issues can you think of that I will encounter and solutions to make fixing them easier?
