mrvette
Phantom of the Opera
OK, in some 18 years and maybe 100k miles, my '72 is on it's 4th set of upper AND lower joints, got some questions about the internal construction of the joints....the guys jack up the lower A arm and so grab the tire this AM at like a 7-1 position, then grab at 11-5 position....and they checking upper and lower joints, and I seen the play myself...maybe up to 1/4 inch.....
so fine, I noted similar shit from the tire shop...I watched it there....
both operations said they worn out....
NOW, when tearing it all down today, I noted the joints appeared perfectly tight outta the car...great tension on moving the ball in the socket, as if it was new...
so the question is....what is the internal construction of the things, and is there any spring or compression device in there???
MY imagination says it's just a round ball with a stem on it, and enclosed in a steel outer casing, BUT are my thoughts correct???
the old joints flexed like the new ones, in other words, but not under the suspension or being jacked up to wiggle the tire....
SO WTF is going on here....you guys know....:hunter:
