Normally the holes are on the side but your block has an additional oil gallery (priority main oiling?) and the holes are at the top and the bottom. Still, the normal retainer should fit.
Is that a ZL1 alu block? Does it have the additional head bolt bosses in the lifter valley?
Yeah.
The four core plugs in the valley kinda worry me. They've got an o-ring for sealing. While I'm sure someone has worked out the bugs for this type of deal, there's just no easy way to ever monitor the sealing integrity of them.
Ahh a brand new one, so you have the pretty blue rear cam retainer plate too, w/ ZL1 engraved on it? Really nice.
'I wouldn't worry about those o ringed plugs.
Gene, yes those plugs are threaded in, common on alu blocks.
Also, those studs that you mentioned in the valley baffle thread, those are for a spider plate to retain factory style dog bone retainers for roller lifters.
Too pretty to put in a car. I'd put it in my living room LOL
Like I said, Gen VI stuff
It's only required for a roller cam, so if you want to use a roller cam, use one that has a stepped front snout/front bearing that is cut down for the retainer plate. Not a retrofit model If using a flat tappet cam you won't need it.
Found a pic... this is it, you can see the stepped cam nose too. This is all the same design as on the small blocks from 87 up, they use the same system It may very well be the same retainer plate, I'm not sure on that.
The 2 little bolts should be button head allens for sprocket clearance, regular allens and socket heads/hex heads will lead to clearance issues.
