68/70Vette
On my 70, I have Tom's trailing arms and Stainless Steel Brake Corporation (SSBC) aluminum rear calipers. I have a set of stainless steel brake lines from In Line Tube for OEM replacements. The brake lines for a stock Corvette will not fit if you have the SSBC calipers. For my 68, with it's VBP trailing arms, the brake lines would fit at the trailing arm input, but not at the SSBC caliper. Now, with my Tom's trailing arms and SSBC calipers, the stock brake line will not fit at either the trailing arm input nor at the caliper input.
What to do?? I talked with In-Line Tube. I'm going to build double flare brake lines out of copper tubing that fit my Tom's trailing arms and the SSBC calipers. The copper lines will have the correct fittings on them. If you want to dummy up brake lines or fuel lines, use copper...it's so easy to work with and double flare. I'll then send the copper lines to In-Line and they will laser scan them and then they will regenerate a new set of brake lines for me in stainless steel with stainless steel fittings. Don't know how much this will cost, but I've had them do some custom work for me in the past and they were very reasonable.
