BangkokDean
Hi, My L98 motor all of a sudden has started bucking or pausing when driving. It idles OK cold or hot 183*. I set the TPS to .54 volts using two paper clips + to the center wire and the – to the top wire.
The fuel pressure with key on is 30lbs and after 30 minutes key off it drops to 16lbs.
When running the fuel gauge bounces all over the place 10 to 50 very fast.
The Trans is a 700R4 I drive in drive and overdrive with the same surging.
Please let me know what you all think the problem is, thanks
