C3 why would one rear tire be in farther then the other on the back
JeffP1167
Yucaipa, CA.
My 82 is like this and I've seen a couple others as well like this. But then saw others that are not like this. Is this an adjustable alignment issue or just a sign of a bent frame?
Measure the center to center distance on your half shafts. Could be that one has been replaced with an early shaft.
also measure from tire edge to frame... mine looks like one is out further it is just that one fender has been replaced and the hack that did it should have left it to someone that knew what was going on :/
