Changing Tires on a Moving SUV
After having been in that part of the world, the only thing I can say is if they had any clue they could get hurt doing that it would have killed them all.
If there were any brains between them it would have killed them all.
If you find a Youtube video on another website you can double-click it and it will take you to the relevant Youtube page.
You can then copy and paste the video in your message without having to go through the outside link.
Like this:
[ame]http://www.youtube.com/watch?v=dvBDeaUMddI&feature=player_embedded[/ame]
If you can stand the music here is some retarded stuff
[ame]http://www.youtube.com/watch?v=UQR3w15i-NA[/ame]
This is where things go wrong:
[ame]http://www.youtube.com/watch?v=hqHh03dYCp4[/ame]
That tire rotating is bad-ass by the way.
Pretty amazing how they did that.
Pretty incredible driving, all of it. Better than anything I can do by far. But I do wonder, in the tire rotating video, how many practice runs did it take to get it right? How many vehicles & people did they go through before they got the perfect run? Those 'outtakes & bloopers' would be interesting to see......
(& do they earn virgins for dying doing that?)
Driving long distances on the sidewalls was really playing with danger since you're just asking for a blowout. The three guys changing tires would be on their way to paradise.
Nothing too bad ass about any of that...all dumb ass.
Like this:
IMO, that first vid is a total fake.....
ain't NO freeking way that can be done.....screw the driving the fact that the upper wheels on what should be a FWD vehicle are not rotating....is clue enough....I can go the front would not be turning if RWD...but not the rear...
even if the jincked the brakes....how they get up to speed much less let it down again??
good photo chop though....
I don't think it's a fake.
That could be done if it's a 4WD, power will go to the wheels that have traction.
NO, power is applied nearly equally to EACH wheel in question....right and left at same speed.....
so to run a open rear on both ends, the typical front drive IS a open rear/front configuration....so no effort there, to make sure the rear is the same.....
I see it they have to jinx the brakes on the upwind side, and lock that axle....
:shocking::beer:
I have always said that any so called 4wd vehicle is not that but at MOST a 3 wheel drive....any RWD OR FWD vehicle is a ONE wheel drive...UNLESS they have a posi/locker setup....
With a standard differential without "Positraction, a limited slip differential, a Detroit locker, etc. engine torque goes to the free spinning wheel. For instance, take a traditional differentially equipped car. Jack up the rear end with both wheels hanging in the air. Use something to grab one wheel to prevent it from rotating. When you speed up the engine, the one wheel hanging in the air will spin. No torque will be delivered to the wheel you've restrained from rotating.
With just a standard differential, the up-in-the-air wheels would be forcefully spinning and no torque would be going to the supporting wheels. With a "Positraction" (limiited slip differential), the torque and power would be going to both the wheels; the ones in the air and the ones on the ground.But the up in the air wheels in the video are turning.
I would guess that the drive shafts to the left side wheels were disconnected.
More about differentials. When I lived in Australia (1986-1991) I had an Australian Range Rover. I had an ARB (an Adelaide, South Australia company) install a install an air locker on my rear differential. First of all, I could lock out the transmission four wheel drive differential (standard Range Rover for the four wheel drive), and then with my ARB rear wheel differential locker, I could lock out the rear end. For this Range Rover to get bogged down, I had to have 3 wheel all spinning to loose traction. Did I ever loose traction? Yes. Once. Driving off road I tried to drive over a big Spiniflex plant. It's a big grass like plant that grows in a clump in the desert. I ended up with all 4 wheels in the air. I wasn't going anywhere. Another driver (Toyota) winched me off the clump. I later learned that getting stuck on one of these Spiniflex plants was very dangerous if you have catalytic reactors. The hot reactors can get the plant burning....it's all downhill at that point.
