Chassis bolt grade guide?
Carburated Nihilist
Montreal, QC
Just bought "Corvette chassis restoration technique", starting to make my bolt shopping list.
However they don't mention the grades of the bolts.
All grade 8, I doubt so, I read somewhere for exemple that the trailing arm to frame bolt was supposed to be grade 5, to allow some flexibility.
I also doubt that fuel/brake clamp bolt needs to be grade 8.
I'd like to find info about what should and what shouldn't be grade 8.
hum.... maybe I should look a the pattern on top of the bolts, from a bolt vendor catalog I see that grade 5 bolt as a 3 branch "star" pattern while grade 8 has a 6 branch "star" pattern.
Still, some bolt have a 5 branch pattern and I'm having a hard time believing body mounts are grade 5 bolt....
OH hell yeh, 5 is plenty there,.....only bolts I have a whole lot of respect for is engine assy bolts....con rods, heads, mains, the like...
:drink::gurney:
5 "star" bolts are SAE grade 7 which probably can't be found these days. The body mounts dont have supply much clamping force (just squeezing the rubber mounts). So grade 5 is probably overkill for them.
The bolts that were supplied in the mount kit I bought were grade 8
While shopping for bolt, the difference in price between grade 5 and grade 8 was insignificant. So a bunch of bolt have been upgraded.
