68/70Vette
Looks like I need to replace the clutch pedal lever. The little pivot shaft on the clutch pedal lever arm is badly worn.
Question: How do I do this? It looks like the clutch/brake lever arm are mounted on a common shaft. The clutch/brake lever assemblies are inside a steel stamped housing apparently. In turn, looking inside the windshield wiper compartment plenum, I can see a rectangular plate held on with four bolts. If I remove the four bolts, will the entire clutch/brake pedal assemblfy just drop out and down.
PS: The interior of the car has been removed and also the windshield wiper assembly has been removed. Also, the Power Brake Vacuum cannister has been removed.
Thanks
Thanks
