Carburated Nihilist
As I'm approaching the time I fire the engine back to life, I'd like some details about my steering setup I'd like to clear out.
I have a Borgeson steering box, that underwent a return to factory due to improper pitman arm installation. So it's supposed to have been double checked by the guy at Borgeson.
First concern is alignement.
I aligned my steering column, using flasher return mechanism, I ended up with the flat spot in the column shaft pointing a 12:00, which sounds logical.
When I align this flat spot with the screw on the U-joint and connect to U joint to the steering box, the whole setup is misaligned by a 1/8 of a turn.
I still have to check the wheel geometry, but I doubts it could account for such a large misalignement.
Second is steering box operation
Hoses are connected, but the box is not filled nor under pressure yet. When I try to turn the wheels, I got a huge slack in the steering, and the slack is from the steering box itself. I'd say 1/8 to 1/4 of a turn before the box start transmitting the steering wheel shaft motion to the pitman arm.
I though the steering box would retain a solid connection between column shaft and pitman arm motion, power assisting only easing the motion.
Any remark/comment are welcome.
