73 Mike
I'll drive it someday
I finally had the time last weekend to sort out my fuel flow issues and get the engine started. For those that don't remember, I bought a junky, low compression crate engine to replace my nice stroker that kind of blew up.:bomb:
The engine started up fairly nicely and was prelubed. RIght off the bat, i noticed that even with the electric drill on the prelube tool, there was a lot of resistance and LOTS of oil flow. I verified this by forgetting to put a filter on at first. Excellent oil flow. :suicide:
On start up, the oil pressure gauge went all the way high and has stayed there. I haven't put a calibrated gauge on it yet to verify that it's really high, but what could produce very high oil pressure? The engine certainly wasn't new but everything looked quite clean and not worn out.
The other odd issue is that on idle, the engine speed seems to be cycling from high to low and back. I haven't put a tach on it yet but I would estimate that it is cycling between 600 RPM to around 1400 RPM. It cycles steadily and takes about 10 seconds from low to high and back to low. Timing/distributor? This is kind of a new one on me. Oh and Bird, I haven't put in the dizzy that you rebuilt yet. I had to change the hot wire first so I used the old distributor to start it.
Could these be related?
