damper size 1982 and 1986
JeffP1167
Yucaipa, CA.
Is this the correct harmonic damper for this 82 vette seems to be about 1 1/4 inch thick. Trying to put a 86 serpentine drive on this car and was curious if everything will line up with the stock 82 damper.
I thought about using a 88-91 denso a/c compressor and bracket but looks like it will hit the a-arm. plus it requires a extra hole in the head for mounting. The 86 a/c bracket lines up good but cfi fuel lines might need to be bent a tad bit.
