68/70Vette
For a roller frame and suspension, what is the minimum needed for the differential? For sure you need the differential case and the differential cover. What parts are needed in the differential case to contain the half axles?
Background: I have a new frame that I'm building up. The front suspension is all there. Also, the engine (less rods, pistons, camshaft, etc) the bellhousing, transmission (Richmond 5 speed). I want to build up now the rear suspension. Have a lot of parts already...trailing arm spindles, Tom's trailing arms, Tom's strut rod assemblies, etc. I need to build up the differential on the new frame. If I remove the differential from my 1970, then I won't be able to move the 1970 frame and body. Basically at this point the original 1970 frame just has the body on it. I want to keep the 1970 frame and body as a roller so I can have it flat bedded to a body shop for body work. So for my 1970, I'd like to have a differential case and cover and enough of the internal differential parts to keep the rear stock axles located so I could roll the original 1970 frame around. When I've read about the differential, I've read about "C Clips" that keep the half axles retained in the differential case. Is this something is all I need? Basically, what's the minimum parts in the differential that you need just to push the frame and body around by hand on the shop floor and keep the axles linked up. ?
Thanks!
Thanks!
