DJ Dep
refugee from the other place
#23 On the big block intake manifold....the threaded holes. I know the ones on the front of the manifold are all 1/2 inch pipe thread. What size is the one on the top of the manifold in the rear? I think it's a vacuum port for the power brake booster (which I no longer have a use for).
#24. On the front of the manifold is a hole that is used for a "bypass hose" from the water pump to the manifold. What is the purpose of this hose and can it be blocked off? BTW...I am not using a heater core at all.
