electric fan install any tips/ideas to get my setup mounted to the radiator?
JeffP1167
Yucaipa, CA.
it is a GM aluminum/plastic tank radiator that I want to mount 97 camaro LT1 fans to.
I have it all electrically setup to use two GM weatherpack relays and thermostatically controlled for 228on 204 off. This will going into my 82 vette.
One idea I have is to bend some small 90degree tabs and pop rivet them to the upper and lower core rails and then pass s crew through the shroud into the tabs. woul this area of the core be strong enough to hold the fan assembly?
Lets hear some of your ideas.
I have that exact fan shroud. I wouldn't use the core to support the fans. There are 4 lugs on the sides of the fan shroud (2 on each side). Try to attach to them, preferably into the radiator support.
In another thread I described how I did my Spals....tied into the rear tabs of the U shape core supports with angle aluminum going laterally side/side top and bottom, bolt the shroud to that support, never touches the radiator, I be super scared for that thin aluminum and plastic tank rim to support a flea, let alone those fans.....
:twitch::surrender:
How about this, you can see in this picture my original upper radiator retainers, they have a place to bolt what I think was originally the fan shroud.
What about say brackets that attach at these points on the shroud or a flat piece that runs across the shroud and ties to both upper mounts?
Then any space between the the radiator and shroud could be sealed with lowes foam weatherstripping
Jeff, I still think it's easier to just catch the plastic shroud at several points with washers to back up the bolt head/nutz....it seems like they counted on the shroud to support the fan weight, from appearances I can see, sort of like evenly distributing the load/flex for road vibrations....you concept maybe work well too, I just dunno from pix....
All I know is my fans been there for maybe 6? years now, and they fine....
Because the radiator doesn't have the catches for those tabs
OK, I forget about later sharks...over the years...worked on many of them, but can't keep the players straight without a score card....
I know my '72 had some fairly heavy steel U's to catch the rubber mounting, and the rad floated top and bottom on them, putting a hole was easy, adding the struts for the fans....
on your setup, it maybe not work so good, I dunno,.....thought it was the same as mine....
:surrender:
:surrender:
I know on my V6 97 camaro the fans are mounted with the tabs. I'm wondering if a LT1 radiator will fit in my 82 vette.
Here are brass replacement core size. I put the camaro radiator sizes due to that is what these fans came from. I suppose I could move the lower radiator cushions in a bit and mod the upper mounts. However the upper radiator hose is mounted much lower on the tank then what this vans radiator is.
Core Size 26 3/8 x 17 x 2 Rows 3 Tank Inlet 2 3/4 x 18 5/8 Tank Outlet 2 3/4 x 18 5/8 Inlet Connection 1 5/16- 1 9/16 Top Left Outlet Connection 1 9/16 Bottom Right Mounting Channel Transmission Oil Cooler 8 1/2 Construction Copper Brass
97 3.8 camaro radiator
Core Dimensions in Inches 24 1/4 x 17 1/4 x 1 1/4 Inlet Header Dimensions 2 1/2 x 18 3/4 Outlet Header Dimensions 2 1/2 x 18 3/4 Inlet Size 1 5/16 Outlet Size 1 5/16 Mount Type Saddle Mount Oil Cooler 11 1/2 (4 Plate)
97 LT1 camaro radiator
Core Size in Inches 24 3/4 X 17 1/4 X 1 3/8 (1 ROW) Inlet Header 2 1/2 X 18 3/4 Outlet Header 2 1/2 X 18 3/4 Inlet Connector 1 5/16 Outlet Connector 1 5/16 Engine Oil Cooler NONE Trans Oil Cooler 3 PLATE, 11 1/2 inch Comments ALUMINUM W/PLASTIC TANKS
