73 Mike
I'll drive it someday
I'm putting together my replacement engine this weekend. It has been quite some time since I've done this and wanted to make sure that I didn't mess up something basic. Here are a number ofquestions that I wanted to double check:
1) Do people still lap valves? The valves are new and so are the heads.
2) The pistons that I have only have valve indents on one side. They are flat tops so no pop ups. I know that the pop ups go to the outside of the engine (to fit in the chambers). I assume that the valve reliefs go to the inside of the engine?
3) I've never done floating pistons before. The clips look pretty much like the ones used for U-joints. Is there a specific orientation for these? No instructions at all on the Speed Pro website.
3) Back to the floating pistons. I assume that the assembly lube should go on the piston pin where it meets the rod. How about the pin ends where it goes in the piston?
4) Anyone try the Total Seal ring break in powder/dry lube? I was going to simply dip the assembled pistons in oil before assembly.
I'm sure I'll have more questions as I go through it.
Thanks guys.
Thanks guys.
