engine scope
Belgian1979vette
Koersel/Belgium
I can loan an engine scope to test the ignition system (sun device). Old unit, but functional.
How is this connected to an HEI ?
Normally a pickup is attached to the primary lead from coil to dizzy, but this lead is not on the HEI ...
Anyone ?
There's a special pickup from sun
attachment.php
The one TT is holding sets on top of the HEI and gets the signal for the coil output. The inductive pickup is removed and this one is installed in it's place. The Red clip on lead goes to the TACH terminal on the HEI. The black one goes to ground.
Ad says us only. Maybe someone here can act as intermediary. Add his addy in your ebay otherwise you won't be able to bid
IF the guy won't ship it to you, let me know. Get it shipped to me and I'll send it on.
I"m retarred, and can do the same Tim, since you maybe well out in the field, no sweat for me, Glad to help,
I can even submit a bid, if that is helpful.....
the bux are not enough to worry over....
:drink:
