mrvette
Phantom of the Opera
on an L 98 engine....highly modified with an HEI in back the way God intended.....I have had a issue with it,  the forward two bolts on the left/driver's side were basically loose as a goose....my question is  HOW/why??
Engine was is hydro lock, so pulled the heads, took all the top end crap to the head shop, manifold straightened...that area with the lose bolts was out by about .021 inch, I sort of thought it would pull in ok with the new gaskets, but they found a ton of bad valve springs too, so they rebuilt the heads.....
I had another failure on the serpentine '88-91 vette a/c compressor bracket....it was cracked yet again....
my buddy the welder TIG'd it up nice again, and during the welding I asked about how in HELL those two bolts could back off that one of them was thumb/finger tight and the other had no torque to it at all.....
HE is a pro welder, and his opinion of aluminum in general is that it's just such a funky metal that he thinks it happened naturally, just a failure.....
I don't think so....I think that someone loosened them deliberately...as in sabotage.....
what say you guys????
