I got pissed off over all the exhausting/cross support problems on my OEM Muncie '72.....
so with the 700 conversion, I cut the cross member, and fashioned a method of install with two bolts facing fore/aft....
but with several R&R's over the years I got good and pissed this last time around...and had the OEM cross member cut out on the bottom of the pipe loops, and nice/wide on the frame bottom ends...so it essentially is a wide V upside down...rounded on top per stock....
then to build a bridge/truss type lattice in the top of it for strength...
and run the exhaust nice and clean under the entire support....
trick is...I have a welder buddy, second is....it has to be done at HIS house....he not moving that machine, and I don't blame him....
and without his help, NONE of these extensive steel projects would be possible...rack, crossmember, front grill, induction, and a few others...
:harhar::thankyou:
