Factory parking lights into fog lights
vette427sbc
Jersey Shore
Found these cool LED bulbs to replace the 1157 bulbs in the parking light housings.
Very happy with the performance and they are a really simple install.
Heres one during the mock-up stage
And a video of the switch back when the turn signal is put on. All I had to do was add a 50W resistor across the turn sig wiring. The bulb takes care of the switchback feature. These things are BRIGHT :cool:
The website I got them from sucks for linking to but go here:
http://autolumination.com/1156_1157.htm
and do a ctrl+f (PC users) for "80 Watt Cree Led White-Amber Switchback Bulbs"
Great find.
I'm a bit worried about the heat management.
It look like a awfully small packaging for soo much (16) of allegedly '5W' led module and the integrated current limiter. All heat emitters.
Usually you see a single of those modules (which contains several led emitter tightly packed) hooked to a CPU style radiator+fan.
That being said maybe they are cleverly handling heat issues and power management.
I'm really curious to know how they perform overtime.
Great find.
Im a little curious on how long they will last too... The main "fog" beam is only 4 LEDs behind a projector style magnifying lens. The bulb assembly does get a little warm, but certainly not hot to the touch. I do love them though and if they last a few years Ill be happy to replace them with the same units
Found a Hong Kong LED light with 50 billion LED's seems to be colored yellow a bit, and so put that large setup over the food table.....works fine, brighter than the curly cue crap I removed....comes on instantly...but it's only a couple weeks old....
purchased off ebay.....15 bux with shipping....
WEE shell SEE.....
:drink:
Well..... One of the bulbs burnt up. Visible burn marks on the inside of the lens. Im going to order another one and hope that this one was a fluke. :chinese::suspicious:
