I'm thinking they're listed as "stock replacement" like many other Moog springs, as I said the rating is much higher than stock... how much are these ?? The VBP 550lbs springs work great, lots of good feedback from many happy customers... I'm not saying the Moog springs are not good but without any feedback from others who have used them I don't know that I would choose them over the 550's ... ok, if you can get these for like $30 then yes, it's worth trying. The VBP springs are $80 and you can find discount codes online.
I have not seen Moog springs advertized as "performance" springs in any of the catalogs or websites (Corvette parts vendors) ??
Here's what I found on RockAuto's website:
Moog offers two types of coil springs: constant-rate springs that restore handling to its original state, and cargo-coil, variable-rate springs as an upgrade for vehicles that carry heavy loads. Moog's constant-rate springs are built to replace original equipment springs, returning ride height and body sway to original performance levels. Replacing worn coil springs with Moog constant-rate springs restores vehicle handling. The cargo-coil, variable-rate springs change resistance as they compress and become progressively stiffer as the load increases.
Moog provides several features and benefits on both constant-rate springs and cargo-coil, variable-rate springs. On both, we heat-treat the alloy steel to ensure the coils rebound fully and resist sagging. While many coil springs are equipped with protective tubes to insulate the clash of metal on metal, Moog uses a premium urethane tube that will outlast our competitors' PVC tubes on both our constant-rate and variable-rate coil springs.
