7t9l82
anybody change them? is there an easy way? do i need to drop the tank?
yes i guess i dodged the bullet , the line seems o.k. if i do at sometime need to change it i would probably run braided up the frame rail too, or possibly aluminum tubing . this car won't ever be "correct" and i don't want it that way either. the Harley guys say F... the factory:lol:
NOT!!!!!!! aluminum will 'work harden' with vibration, anneal to something brittle as glass, and snap.....had it happen on a boat of mine, years ago, talked to an M/E I used to work with, and he just laughed....so I switched to steel, and cured the problem for some years....
he cautioned me against aluminum or copper lines in anything vibration related....this from nearly 25 years ago.....
:gurney:
