I think you have the sender/pickup in the tank bottom near rear pass side....so what you need do is pop the hose off the steel line going forward on pass frame rail....and drain it into a gas can.....
long as your are doing this, curious if you have a bunch of milky looking coffee slop in the bottom of the tank.....
whenyou can't get any more fuel out, you can pop the clip outta the clamp arrangement by rotating it using a hammer and screwdriver and tapping it around until the 3 tabs align and the thing drops....it does come outta there, but you gotta to the twist on it....watch for the float.....
I did mine a slightly different way for the last gallon or so in the bottom, but you can get a towel in there with a stick and wire to poke it around once you get the filler cap assy off.....
:yahoo:
:yahoo:
When I drain it from the hose and nothing is left, can't I just start the car for the few qts that are left and let it run dry? i will be rebuilding the engine anyway so I am not worry if it suck up some crap.
You don't have to take any of the gas out, but it is always the safest way.
FYI, the tank has a bladder in it and a large metal cover over the complete tank that stays with the frame. You will only need to disconnect the wiring harness to the tank on the rear drivers side high on the tank and the vapor cannister hose by the drivers side gill.
Easiest is to take the rubber hose off the pump supply line (3/8") on the passenger side top of frame rail at the front of car by the mech fuel pump.
Push a 4 ft length of 3/8 hose (any type) onto the steel line on the frame rail.
Start syphon action and aim into gas can(s).
You will empty the tank out just as if you ran dry driving.
Have all this stuff ready before you start, once the gas starts, it keeps coming.
Here is a pic
Out of a 75 with bladder.
I think 20 gallons.
