73 Mike
I'll drive it someday
I ran into a wall last weekend. Literally! I put the last two pistons in the stroker and while doing a "rotation" check, thunk. One of the cylinder walls were not clearanced. I had to borrow a die grinder from Randy on Sunday morning. 45 seconds with a carbide bit and no more intereference!
Anyways,after a long week, I finally can get back to it. I have a deadline down south to meet.
I got my intake gaskets as recommended by Dart for these heads. Although not perfect, I presume that this match is adequate no? In other words, should I be grinding the corners of the intake runners on the hedd to better match? I don't really know what "good enough" is.
The next question. Should I try to grind down the intake to match better? The difference here is much greater but I'm not sure that there will be much aluminum left when I'm done. This is an Edelbrock RPM intake.
I thought that the reason for the poor match was that the runners on the RPM intake are much smaller than the Victor Junior that seems to suit better, but the cross section on the Victor doesn't look much different
As always, thanks for the input.
