It's just a heat sink,used in many products today to dissipate heat,there is one inside you're computer.
If it didn't work, they wouldn't be making these as solution for when you're not running a separate fluid cooler:
BTW, it's an appleton filter/cooler/reservoir.
Jeebus, that thing would drag the ground in a MOTOR HOME.....
:lol::crap:
agreed. this thing will provide a very modest drop in oil temps. especially given the stock location of a SBC oil filter, the amount of surface area the oil is exposed to and air flow available (immediately next to an exhaust manifold to be sure) is just minimal at best. this thing is more a "feel good" mod than any actual benefit mod. you're so far ahead of the game by just putting on a proper oil cooler. now you might see something that is barely measureable with this if you remote mounted the oil filter in the path of cool air.....
When you start pushing the engine beyond “normal driving” limits, the oil can actually start getting hot from the higher bearing loads. For this reason, high performance cars (such as post-’84 Corvettes) have engine oil coolers. On engines without oil coolers, used in high performance applications, a heat exchanger or add-on oil cooler is of benefit to keep oil temperature and engine temperature under control. If this is needed, you’re actually better off installing a “real” engine oil cooler rather than the finned sleeve for the filter – you don’t have limitations on the work you can do on a car.
Lars
I made one exactly like that for a spin-on filter on a motorcycle several years ago. All it is doing is increasing the surface area of the cylinder for increased heat radiation--just like fins on an air cooled engine cylinder. I folded up individual fins from sheet metal and attached them through slots with hose clamps around the filter. It was a pain in the ass, it took 10 minutes to get the fins alligned & flat on the surface each time I changed the filter. More of an exercise just to see if it would work, it did work great as an oil cooler without having to run more oil lines.
Harley Davisdon has/has one in thier accessory catalogue.
Could just go for a bigger oil pan...that would help
Gee, too bad I didn't know that at the time, I would have just......made my own anyway!
