Belgian1979vette
This is a bit off, but maybe someone here can help me.
As some of you know i'm restoring an old dyno that I purchased. I'm at the stage of reassembling the housing after the shaft was redone and balanced. The shaft is sealed in the housing by way of gland packings (rope type seal, packed in graphite).
The shaft itself had a problem in that one of the surfaces where the bearing sits was out of round. This caused the bronze bushing on the shaft to touch the housing in some instances when in operation. I had this corrected, but when trying to reassemble seems that the piece that is going into the housing were the rope seals sit (and that is used to compress the rope seals), is smaller than the bore itsself on the side where the out of round problem was. The bore thus is somewhat larger and if i'm correctly I will probably never get a good seal here. I suppose the problem with the bearing somehow also caused problems at the gland packings and to enlarge this bore in some way.
Any ideas on how to solve this. I already used a filler to correct any minor surface imperfections in this bore. But the amount i need to put in a approximatly 2mm all around, which makes it difficult to get everything perfectly round again after sanding.
Any input is greatly appreciated.
Thanks
Yves
Thanks
Yves
