84rzv500r
Knows just enough to be dangerous!
Just to let you know I was doing some exploration of the rev limiter in the first 4 gears (still 2 more gears to go) on Friday and ran a good bit at 5500-5800 RPM (4th is about 120-126 MPH). When I had accomplished my mission I shifted into 6th and backed off the throttle. I went about 1/4 mile and the water pump impeller cover gasket let go in an impressive display of steam.
Long story short, disassembly shows two problems with the aluminum water pump GM pn 14058915 on my 502 Ramjet.
1) The gasket was improperly installed from the factory and blew out (I'll post a pic. later) @ 2300 miles since new. I had always had a TINY bit of coolant leakage that I could never find. (It leaked only when running
The failure was at 5 o'clock facing the front of the motor. I could feel it with my fingers. You can check by feeling, you would feel the gasket sticking out a fair bit when none should be.
2) Comparing the OEM gasket to the Fel-Pro pn 11725 the OEM gasket was three times thicker, soft and swollen. I assembled dry and checked the impeller clearance. I used the Fel-Pro and a thin coat of aviation form-o-gasket to hold the gasket in place. All is better now.
The gasket was $1.60 plus tax
:twitch:
:twitch:
