73 Mike
I'll drive it someday
A brief background from my last engine thread. During a run I had a bang on accelerating from a stop. The engine stopped but started right back up, but with a noticeable rattle. While trying to localize the rattle, I noted high start up oil pressure. wanted to know if it would go back to normal when hot so took it for a warm up run and it "banged" again and then locked up. Coasted home into the driveway. Drained a couple of gallons of coolant out of the crankcase. Earlier this week I pulled the plugs and found the one in #5 cylinder to be damaged:
Pulled the engine out this morning and began disassembling it. Noted that only one of the pushrods was binding in the # 8 cylinder intake. Not sure what to make of this nor if it is even relevant:
Found bits of piston in the intake yesterday. After pulling the intake, I found a few more pieces. Then I pulled the passenger side head and found the following in cylinder 2:
Pulled the head on the drivers side next. Guess I know where the shrapnel came from:
I'm thinking I know where the coolant leak is too:
If you look closely, you can see a fairly spectacular bend in the connecting rod:
Now it comes down to two questions:
1) What caused it and
2 ) How to fix it.
Just speculating, but I would guess the first bang and rattle were from part of the piston breaking, perhaps at the land. I'll probably never know as an NTSB team couldn't reassemble the shrapnel into a useful piece of evidence.
I would guess that the second bang was when the piston completely gave up the ghost and the rod went through the cylinder wall.
Any other opinions? These were Speedpro hyperleutic pistons.
Now for the important part: what to do to fix it. Unfortunately, without knowing what went wrong, I'm speculating that the same thing won't happen if I rebuild.
I'm assuming that I can put a sleeve in cylinder 5. I may have to do this for cylinder 2 as well as there is a fair bit of pitting in there. THe crank looks fine as, perhaps surprisingly, do the other rods and pistons. Do I swap out to forged pistons? Do I need to replace all the rings and bearings?
Except for some carbon in cylinder 5, the heads look like nothing happened.
I need opinions folks. I'm way out of my element here.
2 ) How to fix it.
