mrvette
Phantom of the Opera
QUOTE=GoVetteGo]Did you have to modify the top of the radiator support for your fresh air intake?
John[/QUOTE]
Yes, I cut it about 4" wide and then bolted a piece of metal with a bend in it, to tie the two sections together, just behind the a/c cond.....down lo in the flat section of the support, I also reverse hinged the hood, using hinges from a Lumina Mini van hood, and I made my own SS hood pin setup with bolts and pins from West Marine....I use a wood stick to hold the hood up.....
For some reason the forum says you not receiving PM's....dunno why....
so I stuck my reply on the board......
John[/QUOTE]
