Help with sensor?
shoeitime
Member
Cibolo Tx
Ok peep's I am having trouble finding if I need this thing back on my new crate engine since the crossfire has been removed.
It went here in my old crossfire engine
YES< that is you oil pressure sending unit, and the switch to kill the fule pump when the engine dies for any reason....fail safe device....
I would leave it and the attendant wiring, as ONE of the wires goes to you oil pressure gauge....maybe two of them.....
and the switch function will have to be thought of when you figger out about what sort of/where the fuel pump will be.......the TBI pump runs nearly ten+ lbs pressure, way too much for a carb....so you either change the pump or stick a regulator in there......OR go mechanical.....
I did a TPI on my '72 here, about 15 years ago....and have worked on a few sharks over the decades....
That one is indeed the oil pressure sender but also the oil pressure switch for the fuel pump. You don't need it anymore, you can use a normal sender instead.
The summit link is a safety switch, which is what's incorporated in that stock one you have there. The only difference is that apart from the fuel pump it also cuts out the coil if the oil pressure is low, that way it can be used with a mech. fuel pump also.
