69427
Need some help with the hood alignment/appearance. I swapped the body onto another frame, and just got around to putting the hood on yesterday. I have it aligned so it latches okay, but the seams aren't as even as they used to be. There are three areas I'm concerned about. The very front (point) edge of the hood sits about a 1/4" above the nose bodywork directly ahead of it, while the sides of the hood (near the 427 emblems) are 1/4 to 3/8 of an inch below the fender curve lines. I'm trying to figure out if I have the front of the body bolted wrong (in the area above the front sway bar), or (if it's possible) if the hood has taken a less-curve set after sitting in a hot attic for the past year or two.
What do I need to do to figure out my problem here? This car has always had very good (for an older Corvette) seam evenness, and I'd like to get back to where it was.
Thanks for any help!
Mike
Mike
