Hood Latches
DC3
Lubbock Texas
It's happened to me a couple of times in my '73 that both hood latches came unlatched while driving. Both times I was turning a corner fairly aggressively and the road was rough (washboard).
I haven't looked at it yet but was wondering if anybody knew if the latches could be adjusted to hold better.
Thanks for the help.
DC
Yes, you can adjust them. It is a hit or miss type deal. Just loosen the bolts and tap the latches over just a very little bit, maybe just 1/32" at a time. You can adjust both the position of the latch and the spring tension. But, with the severe frame twisting of the c3, it may still do it once in a while.
Thanks for the info. I'll give it a try next time I think about it - which means I'll probably forget until the next time it happens.
:beer:
DC
