Horn Relay Stud
Kid Vette
Master-Baiter
Santa Cruz, CA
Anybody know what the thread size is on the horn relay stud? It appears to be a #12?! :huh: This is a '73
Don't know about the relay stud but, in 73, #12-24 was in common use. It was phased out in the late 70's/early 80's when we tried to switch to the metric system. You can stiil buy tap and die for #12.
OK, thanks. Don't think I've run into a #12 before on the Vette. Now I need to find a place that has #12 nuts. :cussing:
Mcmaster-Carr is about the only place that I have found them.
Not sure if this is true but I have heard that a 6mm x 1 will work in a pinch.
