How good is a PB600 intercooled supercharger?
JeffP1167
Yucaipa, CA.
I'm going to buy one for 2800.00 has all the stuff to it, it is a twin intercooler system. It is California smog legal as well so that alone eliminates many choices I have to do something like this. What kind of gains can I expect out of this?
be prepared to spend a lot more. An FMU sucks, so a set of 60lbs or so injectors is what you need, + a custom tune. incl. ostrich + software. The twin intercooled setup is for a corvette? I have a complete set lying around too. The hoses an pipes & especially the hose clamps suck, better off getting some decent stuff.
stock multec injectors will lock up w/ the FMU @ higher pressures, guaranteed
I have a p600b on my camaro
The vette install is even more problematic. Does it come w/ a new inner fender????
P600b on LT1
It comes with 36lb per hr svo injectors and is brand new and designed for a 90-91 corvette. My friend has it and it is all new and never used. Thinking about it for my 90 vette with a auto. Yes it has new fenders, something that relocates something in front of the radiator. Has every possible thing plus 3 pullies ( I think 8lbs, 11lbs, 15lbs)
36lbs won't be enough to get you all the fuel required @ stock pressure. You will still need the FMU. 42lbs is about the minimum and on the ragged edge for a decent motor.
Have exact the same kit lying around here too, also brand new complete w/ the fenders and all. Put it on that C4, it will not fir your C3 without serious modification. It's also for a 88-91 vette I think right????
I think it's for 90-91 only because of the raked radiator verses 84-89 more straightup radiator. He ordered it for his 90
That's what it was then, I forgot. I knew there's a difference between the years. So, 90/91 it is. The 92 up kit uses that funky over the rad intercooler like in the above pic.
Hey you know the exact measurements (side to side) of a c3 and c4 frame rail where the radiator mounts. Have a new mod in mind for my 82.
Yep, I still have the 90 and after looking at it's excellent radiator capsule I would like to adapt one to my 82.
