HVAC Vacuum Line?
I was looking at the vacuum line routing for the vent doors, heater control etc. in the manual. Something does not make sense, I see no check valve in the system. For example, the kick panel vent an an A/C car is spring loaded closed with a vacuum actuator to open it. So if you supplied engine vacuum to it (without a check valve), the door would open and close with changes in vacuum, right?
Looking at the HVAC vacuum diagram, I see no check valve. Also, if there is a check valve, the system has to be vented to release vacuum after the check valve. I don't see where that occurs.
EDIT: I found a diagram that shows a check valve for a 1977. Still can't find how the vacuum is released.
The system check valve is under the hood (1969) near the carb. It is in the line feeding the vacuum storage. There is also a filter if I remember.
George
