I need to find a liquid gasket material that will seal two machined sufaces (engine vacuum) but will not adhere the two pieces together. Silicone would be ideal except for the adhesive properties. Maximun gap is maybe .010 inches.
from what I "heard" Hylomar sold their name to Permatex... you can by a Permatex product and the original Hylomar (yellow tube, made in the UK).
I used the blue Hylomar in the yellow tube many times. Important: read the fine print: if used on bolted joints (metal to metal) the bolts must be retightened after 20-30 minutes, otherwise you might find them loose the next day .....
