BangkokDean
Can anyone identify this SBC please????? posted again
Thanks TT.............do you know if this block can be turned into a 350 with cylinder boring or stroking? Also are the heads any good?Yes, it's a 305 TBI roller block. Judging by the exhaust manifolds it came out of a truck or a van most likely. It's completely worthless IMO
Can't be done. 305 = boat anchor.
Just out of curiousity, would a similar vintage 5.7 litre motor be any good or is that another boat anchor?
87 up 1pc seal has a roller cam. All 305s are junk really. Heads are crap and decent head can't be fitted because of valve shrouding (too small a chamber)
If you want to sink money in an engine at least start w/ a 350.
I just found out the hard way that not all post 87 blocks are roller cam equiped. The trucks didn't get roller cams until mid 90's. The intake valley is drilled for the spyder roller lifter keeper, so turning it into a roller cam block is easy, just that the lifters, spyder retainer thing, and cam is not there. I didn't discover that until I pulled the heads off of my 350 truck block to give the heads away. I need to pull the oil pan to see if it is a four bolt or not. I hope to make this block into a 396 someday.
Bee Jay
Bee Jay
Bee Jay
My '89 truck roller engine has factory 4 bolt mains...
Bee Jay
I wonder how GM decided which truck got roller lifters and four bolt? Is your truck an HD or 2500?
Bee Jay
