Ok probably a really dumb question. Since I have the carb off the car I need to go ahead and replace the intake manifold gasket because it is leaking from the front rtv bead. I have only placed the distributor in when the engine is at top dead center on the compression stroke. Where at do I mark the dizzy to just pull it out and put it back in without having to turn the motor?
Thanks
Wade
Thanks
Wade
