voodoovette
If you look at the attached PIC's closely, you will notice the factory fastener holes are not drilled in the center of the bracket for the lower control arm bracket. The control arm mount bracket is at an angle in relation to the frame bracket. This is factory original and only on the pass side. Can anyone provide the correct measurement between the driver and pass side lower control arm mounts at the centerline for I can figure this out, thank you.:confused2:
