mrvette
Phantom of the Opera
Well John was nice enough to send me a set of 8 for the vette, as some of you may remember, I have had my share of crazy running problems finally culminating in a episode of running outta gas on the freeway ramp a little less than a year ago, and finding about a gallon of water/gas/crap in bottom of the tank, about enough to cover the fuel sock....
I have had my problems with fuel here in Florida....two tank straight away bad some years ago.....fixed that, little known to me is that the problems did not go away, the water/gas issue is much more insidious down here than I ever would think, for the vette anyway.....
SO, in the middle of all this John (Jsup) knowing the full story of the short form above, he still took on the task of sending along a full set of proven/tested/cleaned 24? lbs injectors,
and they run SUPER NICE, just a trip around the block, I can tell a difference in smoothness, lower revving in/out of gear....being a automatic....and smoother idle....I should stick a vac gauge on it, but I remember the readings as being lo but steady...kinda curious over that...need do....
so for the first time in years the thing feels GOOD.....
gotta LOVE 07-08 winter's project, injectors changed in 20 minits....5 bolts, one nut, (shut up, not the nut working on it)......:smash: Went to a LT1 mani/rails on the L98 engine....
John, you do good work, everything was packed well, everyone clean as a pin, the package was such even USPS couldn't drop ship it....
trying to paint the car, engine has been neglected recently, not that it's all super neat looking all the time anyway....
NO JOKES about my friggin' paper clip either...damnit....:smash::cussing:
