knocking sound in body-C3
BangkokDean
Bangkok
Recently I have a noise coming from the driver’s side at the top near the seat belt re tractor. I have removed the re tractor the t-top and the noise is still their. It sounds like metal bumping. After many drive around the block with all the trim removed and the re tractor removed I have come to the conclusion that the bird cage has some how separated from the top roof fiberglass, you can’t see any separation but I think when the body flexes the bird cage is hitting the outer fiberglass causing the knocking sound. I don’t see any way to bond it with out some major work. What I am thinks is to drill a few small holes on the inside of the birdcage and use a spray bomb of the expanding insulation foam, filling the space so the metal cage is not hitting the fiberglass skin.
Does anyone see a better solution?Or can think of what may be causing the knocking sound?
The fiberglass is glued in a couple of spots, above the door edge (where the glass notches and flows into the roof bar) and directly in the middle behind the T bar. These are just big dabs of adhesive and a bitch to get to. I doubt that's where your noise is coming from. There's a good amount of room between the glass and the metal, it would take a lot of distortion to make a noise there. Tracing a noise can be very deceiving, make sure it's not something else first.
If I take the T-bar off can I see the bonded location? Also do you think it will do any harm to shoot some expanding foam in between the metal cross over and the fiberglass roof? I am always looking for something else that could be the noise. It seams like it is right at my left ear.It not in the door or the T-tops as when I drive with the door open and tops off it is still there. I at one time thought it was the body bolt next to the trailing arm as I have just replaced the bushings on the trailing arm. But cant see that it is coming from that point.
I will keep looking, if the foam does not do harm I may go with it.
I'd be all OVER those body mounts, #3 as you said above, and #4 behind the rear wheel, #4 is a famous rust out spot, I had to do mine long time ago...
:gurney::beer:
If I take the T-bar off can I see the bonded location? [/quote[
No, it's on the top towards the rear window. If you remove the interior halo trim you might be able to see it with a small flashlight and maybe a dentists mirror.
I'd be worried about the foam retaining moisture. There's no coating whatsoever on the birdcage and with the leaky t tops right there, asking for problems.
Have you tried the t top receiver? How about the door striker bolt? It threads into a captive nut, the cage for it however is pretty long, a lot longer (taller) than the adjustment in the fiberglass panel over the pillar. IT loose it will rattle.
These noises travel and are a bitch to figure out, the bodies are like the skin on a drum and transmit vibrations. I might take a look at the shocks, diffy and sway bar bushings to see if anything has movement.
I will check that out.
I am thinking to get it up in the air to see what I can see. Thanks guys
If you really want to go for the foam, check out www.uscomposites.com - they're in south FL and I have some of their structural foam... good stuff.... don't think it retains moisture like the "great stuff" foam you buy at the hardware store.
