clutchdust
Millionaire Playboy
I think both have advantages and disadvantages, I'm just trying to figure out which has the most advantage.
From what I've heard, the biggest problem with gear drives is "spark scatter", while it's main advantage is it never loses timing.
A personal experience I have with chains is that anything less than the top end chains and you run the risk of knocking the teeth clean off. I put in a decent Cloyes chain on my overhaul some years back, then later when that engine bit the dust I pulled it apart to discover the cam gear had eaten nearly half the teeth! If going with a chain, and you're hard on an engine, get a set where both sprockets are heat treated.
So what's everyone else's take on the comparison?
