Belgian1979vette
Ok, I put in my rebuild steering column and attached all the wires going to it.
I have 2 questions now (please not a lot was changed on the car when I first got it. I reconnected everything like from the factory so I'm not sure how it should work) :
- my lights don't come up or go down when pulling the light switch. On the other hand I can pull them up or down by the override vacuum switch below the dash. Is the light switch faulty ?
- When I switch to the high beams, the outer normal lights go out. Is this the normal situation ? I think they should both work simultanously when using the high beams (inner lamps)
Thanks
Yves
Thanks
Yves
