JeffP1167
Yes I know of the optispark issues.
My 97 camaro 3.8 has started the dreaded rod/main knock and started using coolant at a concerning rate.
I have done one engine pull on a 4th gen through the bottom.
so my question is this, (keep in mind I live in california so it must have full emissions stuff)
which engine would you use, can the lower hood slope of a 97 create engine/air cleaner clearance issues?
was the lsx in reality more dependable/fuel economy better
seems the 98 f-bodies used 4 channel abs where mine used 3 channel
I for the most part want no electrical nightmare issues
wont be used for super/turbo charger
just want a v-8 to replace my 6 banger with the least amount of hassles.
so is a lsx over a ltx worth it? I have 3.42 gears and disc rear so that isnt a problem
yes I know some say buy instead of build it but I have had this since new and it is still in perfect condition
I am also not looking for performance add-ons now nor later
just the 3.8 rebuild is up about 2500 and for that figure I could buy a totalled 97-98 and just do a v8 conversion.
so lets here "stock" pros & cons of the 2 families
