Stuart73
Member
Is replacement of the modulator valve a do-it-yourself project for a novice? I have a 73 L48 with TH400. The short rubber hose (vacuum hose) that goes from the modulator to the metal pipe is saturated with ATF and leaking. I believe that this means that the modulator valve is leaking. I am getting white smoke at start-up, but trans seems to shift ok.
