clutchdust
Millionaire Playboy
The springs in the used AFR heads I have are barely rated at what my cam is spec'd. So for a while I've been thinking of just putting in a different set of springs. But I'm really wondering now if I would be better off buying a rev kit and just running the old spring (provided I don't have coil bind). I really see an advantage to running the rev kit and the cost would not be significantly different than the valve springs my lift would require. Besides, I'm concerned with the additional weight/inertia effect of the roller lifters vs. the flat tappet lifters I believe most springs are rated for.
