DO2G
Member
I’m ready to upgrade my heads. See specs below:
1978 L-82
4 Speed
3.70 Gears
Edelbrock 2101 Intake
Stock Carb
Dual Exhaust
Stock Exhaust Manifolds
Cam Lunati Spec:
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 227/233
Gross Valve Lift (Int/Exh): .489/.504
LSA/ICL: 110/106
Budget is $1000 on the heads.
Questions:
1. Which heads do you recommend? I was looking at Edelbrock E-Street or Brodix IK180.
2. Which head gasket?
3. Can I reuse my factory rockers and push rods? If not, what would you recommend for use with factory valve covers?
4. What do you think the HP would be?
1978 L-82
4 Speed
3.70 Gears
Stock Carb
Dual Exhaust
Cam Lunati Spec:
LSA/ICL: 110/106
Questions:
