I went out and looked at the differential crossmember of my 1970. I purchased the car in 1992. As far as I know, the differential crossmember has never been removed.....can't be sure, this car has a whole lot of surprises that are surfacing as I dismember it.
The bushing does not touch the frame on this car. Eyeballing it, it looks like there's about a 3/8 inch gap between the bushing face and the frame.
Surprises. The right quarter panel in front of the right wheel and underneath the bumper is a bondo sculpture. The front clip has been replaced, a sheet metal screw used to hold two panels together during repair penetrated the vacuum tank, making it very difficult to remove...it took me a long time just to realize the tank was attached to the body by a screw. Laying underneath the car, using a handheld long hacksaw blade, I was able to run the blade between the body and the tank and tediously saw it intwo. The windshield wiper door bracket on the right side of the car was cracked. Removing the original windshield wiper door caused the attaching bolts to shear, leaving parts of the threads inside the door. Bought a new (used) windshield wiper door from J&D Corvettes in Bellflower, Ca and a new (used) wiper door mechanism from Paragon. ($$$$$$ and time). Sent my wiper motor assembly to Paragon to be restored. They said it was not a 1970 Corvette wiper motor. Back to the front clip. It's really awful. It's been pieced back together from panel fragments. There's a lot of bondo that can be seen underneath. I really need to replace the entire front clip if I'm going to make this a whole car again.
