racervette69
Underachiever
Took my 63 out today. Everything worked except the left turn signals. Anything simple might be causing this? They where working when I stored it last fall.
If the flasher is working on one side it's a good bet or it's possible the turn signal flasher is going bad.
Got them working, for now. It has a small cable, about the size of a guitar string that runs under the dash to a push pull switch. the left was not moving the cable enough to turn the switch on.. must be a 63 thing???
Yes, 1963 only.
